PLMNewbie
1 month agoIdeator I
AML Relationship traversal — filtering items from the related side
I have a relationship between two item types structured as:
ItemTypeA (source) → RelationshipType → ItemTypeB (related)
When querying from the source side it works correctly:
<Item type="ItemTypeA" action="get">
<Relationships>
<Item type="RelationshipType" action="get" select="related_id"/>
</Relationships>
</Item>But when I try to filter ItemTypeB by a property on ItemTypeA using the Relationships block, it returns zero results:
<Item type="ItemTypeB" action="get">
<Relationships>
<Item type="RelationshipType" action="get">
<source_id>
<some_property condition="like">value%</some_property>
</Item>
</source_id>
</Item>
</Relationships>
</Item>Using a SQL subquery in the where attribute is also not an option as Aras explicitly blocks it with:
where="ItemTypeB.id IN (SELECT related_id FROM RelationshipType WHERE source_id IN (SELECT id FROM ItemTypeA WHERE some_property LIKE 'value%'))">
</Item>Error:ItemAnalysisException
SELECT is forbidden in whereattribute
Question: Is there any supported AML syntax to filter items from the related side of a relationship without a separate pre-query? Or is a two-call approach the only supported option?
