Hi Bryan,
.NET 4.7.2 should not be necessary. I was not able to install it at all during my last two Aras server setups, cause I already had newer versions installed. And finally turned out that it was not needed at all, so I simply started to ignore this requirement.
Error 500 is caused by missing 2.1.8 hosting bundle. That´s nothing new of course. But you really have to choose the correct installer. I cover this one in my video around minute 9:21: https://www.youtube.com/watch?v=A5QEtOO86ik
Hope it will work for you as well!
I was able to resolve this issue by installing the .NET 4.7.2 Developer Kit, Uninstalling and Reinstalling Completely. Repair install did not work.
Thanks for the hint! interesting that in your case it was necessary to use .NET 4.7.2. Maybe there is some dependency with IIS settings, so in some setups it´s required, in others not.
- pyscho4 years agoIdeator I
hi AngelaIp!
I looked at the Youtube link you shared and found some tutorials in your suggestion, it was really helpful for me, I also shared your link with some of my friends who are having problems with similar subjects. Thanks!
