Barnali's avatar
Barnali
Update Associated Assembly of a part automatically
When we update a part, for instance we change models, we want the same part in all the associated assemblies to be updated automatically.
Current process
• Look up part to be updated
•  Click on Views and select where used (this is the list of assemblies the part currently exists in)
• Update any details impacted by the change (AML, AVL, and Goals), new part and price
• After save, we must go into each assembly and review where used
• Update by locking, saving and unlocking, then into each assembly here.
We have to follow this process to update each assembly it touches until we get to the Building assembly as that is our very top.
Instead of going to each assembly and updating the part, we want this to happen automatically.
  • Hi Barnali,
    This should be possible by configuring the RelationshipType behavior which you can find more details about in the Just Ask Innovator help menu inside the client.
    It sounds like you'd want to make sure all of these relationships to your Part are configured to be Float relationships, so that they always point to the most recent version. However, this should be the default behavior set on most of these standard relationships. I ran a quick test in my environment by creating a very simple assembly called Parent with a single part in the BOM called Child, and I can confirm that they changes I made to Child were automatically visible when I went back to look at the Parent.
    • Barnali's avatar
      Barnali
      Hi Christopher,
      I checked and the relationship types are configured to float. Is this related to  part lifecycle map, workflows or Item types?
      Thanks,
      Barnali
      • christopher_gillis's avatar
        Hi Barnali,
        I wouldn't think that this is related to the Life Cycle or Workflow.
        Would you be able to provide some steps to repeat this issue? I'm curious what specific piece(s) of information are needing to be manually changed after the part is updated.
