Hi Christopher,
I checked and the relationship types are configured to float. Is this related to part lifecycle map, workflows or Item types?
Thanks,
Barnali
Hi Barnali,
I wouldn't think that this is related to the Life Cycle or Workflow.
Would you be able to provide some steps to repeat this issue? I'm curious what specific piece(s) of information are needing to be manually changed after the part is updated.
- Barnali6 years agoIdeator III
Hi Chris,
I update (change model no) a part Say Part A, the state changes from released to preliminary. Then Click on Views --> Where Used, go to the assemblies where this part A is used. It shows the part A as released in the assembly. Unlock, update and lock the part A in the assembly so that the state changes to preliminary. After updating all assemblies, I change the Part A from preliminary to released.
I would want this process to be automated so that I need not go to each assembly and update the part and change its state to preliminary. Ideally, when I change Part A, the changes and the state of Part A should reflect automatically in all the assemblies where it is used.
Thanks,
Barnali
- christopher_gillis6 years agoCommunity Manager
Hi Barnali,
Ah. I see what the problem is now. You were correct. This is indeed related to the Life Cycle Map. :)
Each state in Life Cycle also has a behavior associated with it. I believe what you were seeing was that the parent assembly was in the Released state which gave it the Fixed behavior. Because of this, when you updated the child part, the parent remained pointing to the last released version of that part.
In order to achieve what you're looking for, you'll need to edit each state in the Part's Life Cycle Map to have the Float behavior instead.
Hi Chris,
Thanks ! This worked but with this change I ran into another problem.
I changed all states in Life Cycle to Float and repeated the same steps as mentioned above. This is what happened:
Opened a Part Say Part A to edit. Clicked on Views --> Where Used. It shows 10 assemblies where it is used. I update (change model no) the part, the state changes from released to preliminary. Clicked on Views --> Where Used. Now it shows just 2 assemblies instead of 10. In these 2 assemblies, the part's state is preliminary though.
Thanks,
Barnali
