2 years agoCatalyst II
"Restricted" can be caused on purpose or by accident.
- By accident if you broke a relationship (related_id links to something that doesn´t exists).
- On purpose when permission or visibility restrictions kick in.
I am a bit confused that your file is indicated as NULL relationship. Check the used permissions for Document, relationship and the File. If you are familiar with the SQL structure, i would directly check the dataset in the table.
