Suhas's avatar
Suhas
Creator III
Technical document PDF publication Conversion task error
Hello All,
While publishing Technical Document in PDF format I'm getting below error:
Aras.ConversionFramework.Exceptions.EventCallbackErrorException: See inner exception for details: ---> System.Exception ---> System.Web.Services.Protocols.SoapHeaderException: An error occurred creating the configuration section handler for ConverterSettings/PdfPublishingConverter: Could not load type 'Aras.Publishing.Configuration.PdfConverterConfig' from assembly 'System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a' (C:\12_Aras_New\ConversionServerConfig.xml line 8)
at System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall)
at System.Web.Services.Protocols.SoapHttpClientProtocol.EndInvoke(IAsyncResult asyncResult)
at Aras.ConversionFramework.Proxy.ConversionService.EndConvert(IAsyncResult asyncResult) in C:\Builds\CI\14740\Innovator.git\CompilableCode\_CommonFiles\ConversionService\ConversionService.cs:line 85
at Aras.Server.Core.InvokeStandardConverter.ConvertCallback(IAsyncResult ar) in C:\Builds\CI\14740\Innovator.git\CompilableCode\Core\InternalMethods\InvokeStandardConverter.cs:line 131
--- End of inner exception stack trace ---
at Aras.ConversionFramework.Models.ConversionTask.<>c__DisplayClass40_0.<OnConvertCompleted>b__1() in C:\Builds\CI\14740\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\ConversionTask.cs:line 281
at Aras.ConversionFramework.Models.ConversionTaskEventHandler.Execute(ConversionTask task) in C:\Builds\CI\14740\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\ConversionTaskEventHandler.cs:line 143
at Aras.ConversionFramework.Models.ConversionTaskEventHandler.Execute(ConversionTask task) in C:\Builds\CI\14740\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\ConversionTaskEventHandler.cs:line 185
at Aras.ConversionFramework.Models.ConversionTask.ExecuteEventHandlers(ConversionTaskEventType eventType) in C:\Builds\CI\14740\Innovator.git\CompilableCode\ConversionFramework\ConversionManager\Models\ConversionTask.cs:line 349
XML & HTML publication conversion is working fine.
Regards,
Suhas
  • Hello Suhas,
    Did you add component for PDF conversion in config file?
    • Suhas's avatar
      Suhas
      Creator III
      Hello SunilReddy,
      Yes, I have followed all the steps which are mention in Aras document.
      Regards,
      Suhas
      • SunilReddy's avatar
        SunilReddy
        We should also add username and password some where in config file, I had this error initially and we were able to resolve it by adding username and password
  • Most likely this is caused by some missing element in the conversion server ConverterSettings section. Can you double check if all tags in ConversionServerConfig.xml are appropriate. Or else you can paste the xml file content here so I can see if something is there I can help with.
