Jayrajvh
5 years agoCreator II
Most likely this is caused by some missing element in the conversion server ConverterSettings section. Can you double check if all tags in ConversionServerConfig.xml are appropriate. Or else you can paste the xml file content here so I can see if something is there I can help with.
