Silly question but, I don't see any obvious place to setup my report query with AML, only the graphics interface. Am I missing something?
To be honest, I am not sure where to add this one. Somewhere in the beginning you specify the used ItemType and select the properties you want to display. You should be able to specify a filter somewhere.
I would add a filter for is_released=1 AND generation > 0 . And maybe "config_id is not null".
But I am just guessing. Better ask Aras support to get a more reliable answer!
As you use Self-Service Reports you probably have a subscription. In this case pay attention for the next Innovator version Innovator 24 which will appear pretty soon.
This one will introduce a complete new Reporting engine, which from my POV will replace the SSR completely over the long term run. When I have to make a prediction: The current SSR service (based on an external reporting software) will be set to EOL next year and you will be encouraged by Aras itself to update and switch to the new better Reporting variant.
The current SSR service has a couple of limitations and was mainly a "first experimental approach" for Aras to build the QueryBuilder.
- kaftab14 years agoCreator I
I believe you can apply the condition here:
Btw, I was wrong with my Innovator 24 tip. It doesn´t seem to contain the new report service yet. Roadmap was misleading....
- Morris893 years agoIdeator I
Self-service reporting enables business users to generate reports & insights. Explore how it works, types of reports, benefits & the leading.
- Morgan3 years agoCreator III
Can you use query builder to setup a self service report?
Not yet. Aras right now is working on the new report service that offers this feature. Not sure if it´s already included in Innovator 27 that comes this month. Keep an eye on the roadmap!
Current self-Service Reports were some kind of a test balloon for Aras. Some ideas of the Self-Service report (external engine!) were reused in their own Query builder. But they are not compatible.
Self-Service reports will be discontinued as soon as the new Report engine is available.
