Hey Gopikrishnan,
Have you tried containing it in a subflow? We've done this with our workflows and seems to work well.
To accomplish this you will need to have an activity step on your main workflow with a workflow in the subflow area that contains your parallel activity steps and end steps for each possible path from the subflow with a method that assigns the path name to a property on you Item that the workflow is running on (this is the way I do it there may be a better way). When leaving the subflow it will need an automatic activity that has all the possible paths and a method that assigns the path it needs to go down. When the subflow closes it will close your parallel steps and go to the rework step.
Steps:
- Create a workflow with your parallel steps in it.
- The start activity on the workflow will need to have default paths to all the first parallel steps.
- The workflow will also need end activities with methods that can choose the paths you need to take on the way out.
- I have mine setup so that the method gets the name of the end activity which matches the name of the path that needs to be taken and sets it on the item the workflow is running on as a property called "wfbranch".
- examples:
- End Activities in Subflow:
- Complete
- Cancel
- Rework
- Paths from Auto Activity outside of subslow:
- Complete
- Cancel
- Rework
- examples:
- Your forward moving end activity will need to be a wait for all inputs. This is so all the parallel activities can finish before closing the subflow.
- Rework steps will just need to be end steps.
- Add an activity to your main workflow and assign the workflow you created as the subflow.
- Add an automatic activity after your subflow activity.
- Add a single path from your subflow activity to the automatic activity and make it the default.
- Add all possible paths that can be taken to the automatic activity and add a method to it that will determine which path to take based on the property that was set on the end steps.
Note: We are currently trying to do this with 2 subflows that need to move in parallel and are having an issue where one of the subflows stays open. Outside of that scenario this works like a charm.
Methods you will need:
C# method sets the wfBranch on End Activity of subflow:
Item itm = this.apply("GetControlledItem");
string wfBranch = "";
wfBranch = this.getProperty("keyed_name");
itm.setAction("edit");
itm.setProperty("wfbranch", wfBranch);
itm.apply();
return this;
if you don't have the GetControlledItem method you can find it here....
https://gist.github.com/YoannArasLab/817184c84b7dec9e0dd3105c9d456632
C# Method that tells Automatic activity which path to take:
Aras.Server.Security.Identity plmIdentity_New = Aras.Server.Security.Identity.GetByName("Aras PLM");
bool PermissionWasSet_New = Aras.Server.Security.Permissions.GrantIdentity(plmIdentity_New);
string branch = itm.getProperty("wfbranch");
Item itmActivityPaths = this.newItem("Workflow Process Path", "get");
itmActivityPaths.setProperty("source_id", this.getID());
itmActivityPaths.setProperty("is_default", "1");
itmActivityPaths.setAttribute("select", "id");
Item itmUpdateActivityPaths = itmActivityPaths.apply();
if(itmUpdateActivityPaths.getItemCount() > 0){
itmUpdateActivityPaths.setAction("edit");
itmUpdateActivityPaths.setProperty("is_default", "0");
itmUpdateActivityPaths = itmUpdateActivityPaths.apply();
if (itmUpdateActivityPaths.isError())
return inn.newError("WFBranchChk: 1. Error updating default path: "+ itmUpdateActivityPaths.getErrorDetail());
Item itmAssignDefaultPath = this.newItem("Workflow Process Path", "get");
itmAssignDefaultPath.setAttribute("select", "id");
itmAssignDefaultPath.setProperty("source_id", this.getID());
itmAssignDefaultPath.setProperty("name", branch);
Item itmSetDefaultPath = itmAssignDefaultPath.apply();
itmSetDefaultPath.setAction("edit");
itmSetDefaultPath.setProperty("is_default", "1");
itmSetDefaultPath = itmSetDefaultPath.apply();
if (itmSetDefaultPath.isError())
return inn.newError("WFBranchChk : 2. Error setting default path: "+ itmSetDefaultPath.getErrorDetail());
if (PermissionWasSet_New)
Aras.Server.Security.Permissions.RevokeIdentity(plmIdentity_New);
return this;
