Hi Mikael
You can use below piece of code to achieve this.
Step 1: Open Workflow of ECO
Step 2: Click on path "Fast Track Approve"
Step 3: Add below method as Pre Methods event
//Method Type : Server Side (C#)
Innovator inn = getInnovator();
//Allowed Identities (CM and Adminstrators Identity ID)
string allowedIdentity = "F6624E9AE5504958A84E4B6A5831298B,2618D6F5A90949BAA7E920D1B04C7EE1";
string path = this.getProperty("name");
string userID = inn.getUserID();
Item alias = inn.newItem("Alias", "get");
alias.setProperty("source_id", userID);
alias.setAttribute("select", "related_id(id)");
alias = alias.apply();
if (alias.isError()) {
return alias;
string aliasId = alias.getProperty("related_id");
string whereCondition = "[Member].related_id=\'" + aliasId + "\'";
Item IdentityCheck = inn.newItem("Member", "get");
IdentityCheck.setAttribute("where", whereCondition);
IdentityCheck.setAttribute("select", "id");
IdentityCheck.setProperty("source_id", allowedIdentity);
IdentityCheck.setPropertyCondition("source_id", "in");
IdentityCheck = IdentityCheck.apply();
if (IdentityCheck.isError()) {
return inn.newError("Only Members of CM and Administrators Identity can select this Path. Please reselect the Path");
return this;
Thank You
Gopikrishnan R
Sorry, but didn't work for me
In the Stage for Fast Track Approve I have two identity groups assigned
"Group1" with User A and User B
"Group2" with UserC
UserA, just a standard user, not CM or Admin,
UserA claims the stage and when UserA selects "Fast Track approve",
It works for him and ECO is forwarded
It should have according to the method being stopped
Any idea why UserA was able to forward though fast track approve?
