Hi
I guess this need to be handled through code as the requirement is disable all fields except password. I guess below blog might help
https://community.aras.com/f/development/35923/disabling-all-fields-in-the-form-using-method
disabling the fields is another variant, but it´s still 'just' a client side solution. It´s sufficient for most use cases as a client side approach helps to prevent accidental unintended changes by the user.
But me being the 'Ultimate (self-proclaimed..) Innovator security expert' I still would prefer a real restriction on server side.
There is a community project that uses property based permissions, but I am not sure if we should use it on a core item. One other variant would be to replace the existing "Change Password" Action with a custom version that just grants permission to overwrite the password of ones own account. But I am not sure if this would open up an unwanted backdoor.
- miraks6 years agoCreator II
Hi Angela,
I switched the "readonly" property to 1 for some properties of the User ItemType (login_name, first_name, last_name) with this code:
var ws = innovator.newItem("Property", "merge");
ws.setAttribute("where", "id IN ('6C3BE07832AA41028237F2FA79EBC069', 'E96F463BC35146A1AC1A0D92AC0C2A6E', '7188DFCEC22147DC97F10239607ADDFA', '86EC9DD76D504543BAF6AFC372187C36')");
ws.setProperty("readonly", "1");
var r = ws.apply();
if(r.isError()) output+=r.getErrorString();Thank you again.
