Apopo's avatar
Apopo
Office connectot error
Hi all,
I just installed the connector for Office suite, and when connecting to Aras data base, I am getting the following error:
Thanks in advance.
  • Apopo,
    The 401 Unauthorized error would most likely be returned if you had a problem with your login information. Can you describe the steps you took before that error appeared? Typically I would expect you'd have had to log in, and then either got accepted or rejected by the login page.
    Alternately, it might be the result of a version mismatch. Which version of Aras Innovator are you trying to connect to, and which version of the Office Connector are you using?
    Skyler C.
    • Apopo's avatar
      Apopo
      Hello Skyler,
      Thanks for the quick response.
      The connector is well installed, when trying to create new aras document from Word, a windows is opened and I have to fill the Database, username and password as in the image below :
      When I click on Login, I get the error.
      I am using Aras 12.0 and the connector is 11.0. Is there any problem with this? Otherwise how can I get the 12.0 connector?
      Ayoub
      • Skyler_Crossman's avatar
        Skyler_Crossman
        Ayoub,
        A major version mismatch would tend to create problems. Service packs and revisions tend to intermix more easily.
        Where did you get the 11.0 office connector? I would expect you (or someone in your organization) to have access to the subscriber portal, which would have downloads for the latest Office Connector.
        Skyler C.
