Amitosh_Tripathy
6 years agoCreator I
How to use it from behind firewall?
necton_labs
6 years agoIdeator II
Hi Amitosh,
You need access to the server in the same way you would from a desktop computer - if your phone is not directly connected to the same network, I think the typical solution would be to use a VPN to connect to the network through the firewall, which should give you access to the Innovator server.
Cheers,
Ben
