Lookup for boolean is not available.
I want to give 'Can Add' permission for two different classification but the identity will be the same. I tried adding the same in Item type configuration I'm getting this error.
Can anybody give me the solution for this?
Thanks
  • Hi
    What was the error you are getting ?. Can you provide more information on this
    Thanks
    Gopikrishnan R
    • Former_Member's avatar
      I was getting Lookup for boolean is not available error when I tried to add the Can Add permission for two different classification using same identity. The reason for the error is we need to save the itemtype before adding classification each time.
