Arif
11 months agoCreator I
Install more than 1 scheduler on a server
I'm setting up multiple Aras Innovator environments on my server. When it comes to installing the scheduler, I'm stuck as there are no instructions on how to install more than 1 InnovatorService on a server. When you try and setup a second one by running the install script, it says there is already an InnovatorService existing and I don't see a way to specify a different service name for a different environment. How can this be done? Can I use the standard windows "sc create" to create the service myself and not use the install tool given by Aras?
