Morgan's avatar
Morgan
Creator III
Impact Matrix not refreshing correctly
Just wondering if anyone has experienced this. We have 3 instances of Aras and on my sample database, after clicking edit the Add button is available right away.
What I am seeing in the instance with the issue is that I have to click refresh to get the add button to show up. After selecting an item and choosing an action, if I try to change the action or delete the row the impact matrix fails and no longer displays anything. Clicking refresh has the same effect.
The other things is that the impact matrix remains editable after selecting Done.
To add some info, the items weve changed so far on the Express ECO are:
The form
The Lifecycle
The workflow
Any ideas?
  • Hi,
    I haven´t seen your exact described behavior, but similar refresh issue. You seem to have give an explanation already.
    You have changed workflow and Lifecycle. But have you also updated the transition handler Method?
    The Express ECO is one of the most complex features in Innovator. It gets very unstable and buggy as soon as you change it like the way you would customize other ItemTypes.
    • Daniels19's avatar
      Daniels19
      Thanks for the update and quick reply. I'll be sure to keep an eye on this thread. Looking for the same issue. Bumped into your thread. Thanks for creating it. Looking forward for solution firstcallonline.
      • Morgan's avatar
        Morgan
        Creator III
        Add the RefreshImpactGridForceServerCall method to the form you have setup for Express ECO as a Form Event as seen below:
    • Morgan's avatar
      Morgan
      Creator III
      Thank you for the reply, I resolved the issue by adding the refresh method to my new form. The one in question is the RefreshImpactGridForceServerCall
Recent Discussions
