7 years agoAccelerator III
Thank you!
It tells me that "The name 'getFieldByName' does not exist in the current context".
7 years agoCommunity Manager
Could you let us know what version of Aras Innovator you're using? I ran my test in an 11.0 SP15 instance, and some of these function names can change between service packs.
I'm using 11.0 SP12 version.
Hi Mille,
It looks like getFieldByName does exist in 11.0 SP12. Could you try explicitly calling this function with window.getFieldByName()? If that doesn't work you could also try getting the field by using standard HTML calls like below.
document.getElementsByName("item_number")[0].getElementsByTagName("input")[0];
This works, Thank you!
