Gopikrishnan
7 years agoAccelerator II
Hi Maddy
I don't find a easier way like SQL but if you still want to implement using IOM, you can write your own custom logic to get this result. I used below method and able to get the expected result.
var itemNums = "Testnumber1,Testnumber2";
HashSet<string> revisionSet = new HashSet<string>();
var partInfo = new Dictionary<string, Tuple<string, string, string>>();
string[] itemNum = itemNums.Split(',');
for(int i = 0; i < itemNum.Length; i++)
revisionSet.Clear();
Item partRevision = inn.newItem("Part", "get");
partRevision.setAttribute("select", "major_rev");
partRevision.setProperty("item_number", itemNum);
partRevision.setProperty("generation", "*");
partRevision.setPropertyCondition("generation", "like");
partRevision = partRevision.apply();
if (!partRevision.isError())
for (int j = 0; j < partRevision.getItemCount(); j++)
var partMajorRev = partRevision.getItemByIndex(j).getProperty("major_rev");
revisionSet.Add(partMajorRev);
foreach(var revs in revisionSet)
Item partLatestRevision = inn.newItem("Part", "get");
partLatestRevision.setAttribute("select", "item_number,major_rev,id,generation");
partLatestRevision.setAttribute("orderBy", "generation DESC");
partLatestRevision.setAttribute("maxRecords", "1");
partLatestRevision.setProperty("item_number", itemNum);
partLatestRevision.setProperty("major_rev",revs);
partLatestRevision.setProperty("generation", "*");
partLatestRevision.setPropertyCondition("generation", "like");
partLatestRevision = partLatestRevision.apply();
if (!partLatestRevision.isError())
var itemNumber = partLatestRevision.getItemByIndex(0).getProperty("item_number");
var itemId = partLatestRevision.getItemByIndex(0).getProperty("id");
var itemMajorRev = partLatestRevision.getItemByIndex(0).getProperty("major_rev");
var itemGeneration = partLatestRevision.getItemByIndex(0).getProperty("generation");
partInfo.Add(itemId, new Tuple<string,string, string>(itemNumber, itemMajorRev, itemGeneration));
return this;
Thank You
Gopikrishnan R
