I tried something similar like this. But did not provide any result .(I am using 12Sp3)
<AML>
<Item type="prj_Phase" action="GetItemRepeatConfig" select ="id" >
<id>Test_id</id>
<Relationships>
<Item type="prj_Phase Activity" action="get" select="related_id" >
<related_id>
<Item type="prj_Activity" action="get" select="state,name" ></Item>
</related_id>
</Item>
<Item type="prj_Phase Child_Phase" action="get" select="related_id" >
<related_id>
<Item type="prj_Phase" repeatProp="related_id" repeatTimes="0" action="get" select="id" >
<Relationships></Relationships>
</Item>
</related_id>
</Item>
</Relationships>
</Item>
</AML>
The syntax for this action can be picky. Try using the syntax below instead.
Note that for simplicity, I've also condensed the query for the prj_Phase Activity relationship. You can query for data from an item property by including an additional set of property names in parentheses inside of your select statement. In this example, I'm getting the state and name properties from the item stored in the related_id by using related_id(state,name). This extra bit isn't necessary for the GetItemRepeatConfig action, but minimizing the size of the queries you write can make it easier to work with them.
- Hyder6 years agoIdeator II
Query is only finding "Activity" which are in parent Phase. It is not able to find Activity inside the 3rd level Child phase. There is no Activity in 2nd levels, only phases..See below representation
Phase Activity1 Activity2 Phase 1 Phase1a Activity3 Activity4 Phase1b Activity5 Activity6 - christopher_gillis6 years agoCommunity Manager
Could you post the AML that you're using now? I tested this in a local instance with a similarly formatted Part BOM and Part Document structure, but I was able to get all of the items I expected.
Thanks for the response
Initially I had the below aml which gave me correct result for 3 levels .
<AML><Item type="Project" action="get" select ="name,id" ><id>${prj_id}</id><Relationships><Item type="Project Activity_Domain" action="get" select="related_id" ><related_id><Item type="prj_Phase" action="get" select ="name,id" ><id>${phase_id}</id><Relationships><Item type="prj_Phase Activity" action="get" select="related_id" ><related_id><Item type="Activity" action="get" select="state,id,name"></Item></related_id></Item><Item type="prj_Phase Child_Phase" action="get" select="related_id" ><related_id><Item type="prj_Phase " action="get" select="name" ><Relationships><Item type="prj_Phase Activity" action="get" select="related_id" ><related_id><Item type="Activity" action="get" select="state,id,name"></Item></related_id></Item><Item type="prj_Phase Child_Phase" action="get" select="related_id" ><related_id><Item type="prj_Phase " action="get" select="name" ><Relationships><Item type="prj_Phase Activity" action="get" select="related_id" ><related_id><Item type="Activity" action="get" select="state,id,name"></Item></related_id></Item></Relationships></Item></related_id></Item></Relationships></Item></related_id></Item></Relationships></Item></related_id></Item></Relationships></Item></AML>This AML always checks 3 levels which is not necessary. I wanted to optimize this. So i tried using repeatconfig. See below AML, but not giving same result as above. This is able to find Activity in 1st level<AML><Item type="Project" action="get" select ="name,id" ><id>${prj_id}</id><Relationships><Item type="Project prj_Phase" action="get" select="related_id" ><related_id><Item type="prj_Phase" action="get" select ="name,id" ><id>${phase_id}</id><Relationships><Item type="prj_Phase Child_Phase" select="related_id" repeatProp="related_id" repeatTimes="0" /><Item type="prj_Phase Activity" action="get" select="related_id(state,id,name)" /></Relationships></Relationships></Item></related_id></Item></Relationships></Item></AML>
