Hi Shruti
Hope you are safe during this Pandemic.
Try refreshing the relationship tabs using below on form populate code
if(aras.getMostTopWindowWithAras(window).frames.relationships)
var iFramesCollection = aras.getMostTopWindowWithAras(window).frames.relationships.iframesCollection;
for (var tabId in iFramesCollection)
iFramesCollection[tabId].contentWindow.location.reload();
Hi Gopi,
I am good , Hope you are safe as well
I tried the above , However while the Form Populates there is no such tab available in the UI, As per my understanding the tab is added only after the CUI changes are implemented.
I tried the Refresh button on the form as well but with no luck.
Regards :)
- pankaj27_b4 years agoIdeator I
Hi Shruti,
Any luck on this issue. Even I am facing the same issue.Thanks,
Pankaj
