Hi Christopher
I want to do duplicate Part check based on xProperties values
Example: Part001 has xp-height :10 xp-length : 10. When user creates Part002 with same xp properties value, system should not allow.
My approach was trying to fetch the Part with xp-height and xp-length with particular value and if data exist prevent save.
When using below AML query, getting count '1' which already exist
<AML>
<Item action='get' type='Part' select='xp-*'>
<xp-height>10</xp-height>
<xp-length>10</xp-length>
</Item>
</AML>
when user filled only height then, AML query will be like below and also getting count '1'
<AML>
</Item>
</AML>
Can someone give some hint on how to achieve this
- angela7 years agoCatalyst II
Also SQL is not recommended for regular use, it´s often a big help, espcially when you have to do data validation.
I still use the regular properties and have not moved to xProperties yet, but I alread have made some tests. The followoing is not final and may contain errors. Please tell me, if you notice a bug in the query!
For SQL you have to know the involved ItemType stucture:
Part -> Part_xClass -> xClass -> xPropertyValuesThis query should work as regular view in the SQL Server Management Studio:
SELECT innovator.PART_XCLASS.id
FROM xp.XPROPERTYVALUES INNER JOIN
innovator.XCLASS ON xp.XPROPERTYVALUES.id = innovator.XCLASS.id INNER JOIN
innovator.PART_XCLASS ON innovator.XCLASS.id = innovator.PART_XCLASS.RELATED_ID INNER JOIN
innovator.PART ON innovator.PART_XCLASS.SOURCE_ID = innovator.PART.ID
Edit: This solution is intended for validation, but not as Method used in the system. But I wonder if it is possible to use the "Unique" properties in ItemType xPropertyvalues for this purpose? Something similar is done in the Part_Goal ItemType that uses a combination of id and a second property to prevent duplicate Goals. It´s an interesting use case. I would also be interested in a solution for this one.
