Hi AngelaIp,
Thank you for your advice.
fortunately I've just checked CE_LinkManufacturer Method only, I don't change any parameter.
Regarding the manufacturer record, I cannot add Manufacturer name in other menu.
And Manufacturer name looks link to the cloud Manufacturer... ?
But I'm not sure I cannot access Cloud Manufacturer from sourcing menu.
Anyway, error dialog is indicated client side error.
It's very curious I can find unknown CE manufacturer name from inquiry dialog.
But that manufacturer name is invalid data . because I could not add it before.
I don't know why invalid data is existed in the inquiry.
I'm thinking whether should re-install aras innovator and SQL server.
Best Regards!
have you looked at the 'Linking Manufacturers' chapter in the CE User Guide?
Just to be sure:
- Are you able to add regular Manufacturer items at all? E.g. when you create a new Manufacturer and add the name by your self, can you save this item?
- Can you do a regular search for CE Parts in Cloud Manufacturer Parts? If this one already makes trouble, you may have some general connection problem with CE.
I really recommend you to write an email to Aras support. They are quite good in CE troubleshooting!
- M_kaneda6 years agoCreator I
Hi AngelaIp,
I overlooked some point in the CE user guide.
My new findings from your advice as below:
I had read the CE user guide chapter 3 (Open Edition (Level 1) user guide.
1.For our system, we cannot open Cloud Manufacturer Part Search.
→Exactly, I cannot see search box as user CE user guide Figure 38.
So We "may have some general connection problem with CE"
2.I tried to add part by "Manufacture Parts".
→I can save the parts information except "Manufacturer name".
3.Tried to modify Manufacturer Part
Detected error as below
<SOAP-ENV:Envelope xmlns:SOAP-ENV="">schemas.xmlsoap.org/.../"><SOAP-ENV:Body><SOAP-ENV:Fault xmlns:af="">www.aras.com/.../faultcode><faultstring><![CDATA[Line number 56, Error Number: CS0234, The type or namespace name 'CE' does not exist in the namespace 'Aras' (are you missing an assembly reference?)
]]></faultstring><detail><af:legacy_detail><![CDATA[Line number 56, Error Number: CS0234, The type or namespace name 'CE' does not exist in the namespace 'Aras' (are you missing an assembly reference?)
]]></af:legacy_detail><af:exception message="Line number 56, Error Number: CS0234, The type or namespace name 'CE' does not exist in the namespace 'Aras' (are you missing an assembly reference?) " type="System.ApplicationException"/></detail></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>As you recommend, I'll try to understand ARAS innovator well and ask ARAS support this case.
Best Regards!
- Kriengsak_P6 years agoIdeator I
Did you solved this problem, I have the same problem
Hi Kriengsak_P
Regarding this failure for our case, we're using ARAS without subscription components.
For my understanding, Utilize of CE_LinkManufacturer is needed subscription which is for Manufacturer database.
I'm verifying original setting without any other package.
