Maybe the solution is more simple. In your screenshot you tried to start the sync from a new created part. Do you get the same error message when you try to sync an existing part?
- M_kaneda6 years agoCreator I
Hi AngelaIp,
Hi Gopikrishnan,
I tried the case which your advice.
1.If I try to make a new parts, disable to add the data without choosing the manufacturer of pull down menu.
2. I found some warning in method CE_LinkManufacturer source.
I'll upload source code of CE_LinkManufacturer next reply
I found warning mark Line 77,88 and 123.
looks these line grammar is incorrect.. but I'm not professional of Java script.
I'm checking them now.
--------------------<below is CE_LinkManufacturer code>---------
//Get settings for 'Manufacturer'
var formattedSettingsItm = new Item('ItemType', 'CE_GetFormattedSettings');
formattedSettingsItm.setProperty('cloud_itemtype', 'Manufacturer');
formattedSettingsItm = formattedSettingsItm.apply();if (formattedSettingsItm.isError())
top.aras.AlertError('Unable to get formatted settings for "Manufacturer" cloud type: ' + formattedSettingsItm.getErrorString());
return;
}var propertyMappingItm = formattedSettingsItm.getItemsByXPath('Relationships/Item[@type="Property Mapping"]');
var manufacturerItemTypeName = formattedSettingsItm.getPropertyAttribute('local_itemtype', 'name');
var manufacturerCeObjectIdPropertyName = propertyMappingItm.getPropertyAttribute('ce_object_id', 'name');
var manufacturerCeSourcePropertyName = propertyMappingItm.getPropertyAttribute('ce_source', 'name');
var manufacturerCeSyncDatePropertyName = propertyMappingItm.getPropertyAttribute('ce_sync_date', 'name');
var manufacturerManufacturerNamePropertyName = propertyMappingItm.getPropertyAttribute('mfr_name_1', 'name');
var manufacturerCeManufacturerNamePropertyName = propertyMappingItm.getPropertyAttribute('mfr_name_2', 'name');var isMainGrid = (typeof(parent.itemTypeName) === 'undefined');
var aWindow = top.aras.getMostTopWindowWithAras(window);if (aras.commonProperties && aras.commonProperties.SearchCountModeException) {
aras.commonProperties.SearchCountModeException.push('03278E95AFE34B7EA0B352EAA85AE021');
var args = {
aras: aras,
type: 'SearchDialog',
dialogWidth: 700,
dialogHeight: 450,
itemtypeName: 'CE_CloudManufacturer'
var dialog = (aWindow.main || aWindow).ArasModules.MaximazableDialog.show('iframe', args);
dialog.promise.then(callback);//Add 'gridLinkClick' event handler
var intervalId = setInterval(function() {
try
var contentWindow = dialog.dialogNode.childNodes[1].childNodes[0].contentWindow;
var grid = contentWindow.grid || contentWindow.gridApplet;if ((typeof(grid) !== 'undefined') && (grid !== null))
clearInterval(intervalId);
dojo.connect(grid, 'gridLinkClick', onGridLinkClickEventHandler);
catch(e)
}, 300);function callback(res)
aras.commonProperties.SearchCountModeException.pop();
if (isNullOrUndefined(res)) {
return;
var item = res.item;
if (!isNullOrUndefined(item))
//Get item from cache or from server
var manufacturerId = aras.getVariable('CE_CurrentItemId', '');
var manufacturerItm = aras.getItemById(manufacturerItemTypeName, manufacturerId, 0);if (!isNullOrUndefined(manufacturerItm))
var objectId = top.aras.getItemProperty(manufacturerItm, manufacturerCeObjectIdPropertyName, '');if (objectId !== '')
var res = top.aras.confirm(manufacturerItemTypeName + ' is already linked. Are you sure you want to overwrite the link?');
if (!res) {
return;
}var localManufacturerName = top.aras.getItemProperty(manufacturerItm, manufacturerManufacturerNamePropertyName, '');
var cloudManufacturerObjectId = top.aras.getItemProperty(item, 'mfr_object_id', '');
var cloudManufacturerName = top.aras.getItemProperty(item, 'mfr_name', '');
var cloudCeSource = '1';top.aras.setItemProperty(manufacturerItm, manufacturerCeObjectIdPropertyName, cloudManufacturerObjectId);
if (localManufacturerName == '')
top.aras.setItemProperty(manufacturerItm, manufacturerManufacturerNamePropertyName, cloudManufacturerName);
top.aras.setItemProperty(manufacturerItm, manufacturerCeManufacturerNamePropertyName, cloudManufacturerName);
top.aras.setItemProperty(manufacturerItm, manufacturerCeSourcePropertyName, cloudCeSource);
top.aras.setItemProperty(manufacturerItm, manufacturerCeSyncDatePropertyName, '');if (!isMainGrid)
//Update form
aras.RefillWindow(parent.item, parent, true);
} else {
//Update MainGrid
aWindow.main.work.searchContainer.runSearch();
}function onGridLinkClickEventHandler(str)
try
var link = (str.split(',')[1]).replace(/'/g, '');
window.open(link, '_blank');
catch(e)
return;
}function isNullOrUndefined(param)
return ((typeof(param) === 'undefined') || (param == null));
}- M_kaneda6 years agoCreator I
Hi!
Below is result Debug Link Manufacturer
Checking syntax...
ERROR: 45AFF9E39A6A41E58F80DFA14402C476.
Line number 2, Error Number: CS1012, Too many characters in character literal
Line number 3, Error Number: CS1012, Too many characters in character literal
Line number 8, Error Number: CS1012, Too many characters in character literal
Line number 12, Error Number: CS1012, Too many characters in character literal
Line number 14, Error Number: CS1012, Too many characters in character literal
Line number 15, Error Number: CS1012, Too many characters in character literal
Line number 16, Error Number: CS1012, Too many characters in character literal
Line number 17, Error Number: CS1012, Too many characters in character literal
Line number 18, Error Number: CS1012, Too many characters in character literal
Line number 19, Error Number: CS1012, Too many characters in character literal
Line number 21, Error Number: CS1525, Invalid expression term '='
Line number 21, Error Number: CS1012, Too many characters in character literal
Line number 25, Error Number: CS1012, Too many characters in character literal
Line number 28, Error Number: CS1513, } expected
Line number 28, Error Number: CS1002, ; expected
Line number 29, Error Number: CS1012, Too many characters in character literal
Line number 29, Error Number: CS1002, ; expected
Line number 29, Error Number: CS1513, } expected
Line number 30, Error Number: CS1002, ; expected
Line number 30, Error Number: CS1513, } expected
Line number 31, Error Number: CS1002, ; expected
Line number 31, Error Number: CS1513, } expected
Line number 32, Error Number: CS1012, Too many characters in character literal
Line number 32, Error Number: CS1002, ; expected
Line number 33, Error Number: CS1597, Semicolon after method or accessor block is not valid
Line number 34, Error Number: CS1012, Too many characters in character literal
Line number 35, Error Number: CS1519, Invalid token '(' in class, struct, or interface member declaration
Line number 35, Error Number: CS8124, Tuple must contain at least two elements.
Line number 35, Error Number: CS1519, Invalid token ';' in class, struct, or interface member declaration
Line number 38, Error Number: CS1003, Syntax error, ',' expected
Line number 40, Error Number: CS1003, Syntax error, ',' expected
Line number 41, Error Number: CS1003, Syntax error, ',' expected
Line number 41, Error Number: CS1026, ) expected
Line number 44, Error Number: CS1519, Invalid token 'if' in class, struct, or interface member declaration
Line number 44, Error Number: CS1031, Type expected
Line number 44, Error Number: CS8124, Tuple must contain at least two elements.
Line number 44, Error Number: CS1026, ) expected
Line number 44, Error Number: CS1519, Invalid token 'typeof' in class, struct, or interface member declaration
Line number 44, Error Number: CS1519, Invalid token '!=' in class, struct, or interface member declaration
Line number 44, Error Number: CS1012, Too many characters in character literal
Line number 46, Error Number: CS1001, Identifier expected
Line number 47, Error Number: CS1519, Invalid token '(' in class, struct, or interface member declaration
Line number 47, Error Number: CS1031, Type expected
Line number 47, Error Number: CS1026, ) expected
Line number 47, Error Number: CS1012, Too many characters in character literal
Line number 47, Error Number: CS1519, Invalid token ''gridLinkClick'' in class, struct, or interface member declaration
Line number 47, Error Number: CS1519, Invalid token ')' in class, struct, or interface member declaration
Line number 50, Error Number: CS1022, Type or namespace definition, or end-of-file expected
Line number 50, Error Number: CS8124, Tuple must contain at least two elements.
Line number 51, Error Number: CS1022, Type or namespace definition, or end-of-file expected
Line number 52, Error Number: CS1022, Type or namespace definition, or end-of-file expected
Line number 53, Error Number: CS1022, Type or namespace definition, or end-of-file expected
Line number 55, Error Number: CS1001, Identifier expected
Line number 67, Error Number: CS1012, Too many characters in character literal
Line number 67, Error Number: CS1011, Empty character literal
Line number 72, Error Number: CS1011, Empty character literal
Line number 74, Error Number: CS1525, Invalid expression term '='
Line number 74, Error Number: CS1011, Empty character literal
Line number 76, Error Number: CS1012, Too many characters in character literal
Line number 82, Error Number: CS1011, Empty character literal
Line number 83, Error Number: CS1012, Too many characters in character literal
Line number 83, Error Number: CS1011, Empty character literal
Line number 84, Error Number: CS1012, Too many characters in character literal
Line number 84, Error Number: CS1011, Empty character literal
Line number 88, Error Number: CS1525, Invalid expression term '='
Line number 88, Error Number: CS1011, Empty character literal
Line number 94, Error Number: CS1011, Empty character literal
Line number 108, Error Number: CS1001, Identifier expected
Line number 112, Error Number: CS1525, Invalid expression term '/'
Line number 112, Error Number: CS1012, Too many characters in character literal
Line number 112, Error Number: CS1003, Syntax error, ',' expected
Line number 112, Error Number: CS1010, Newline in constant
Line number 113, Error Number: CS1012, Too many characters in character literal
Line number 113, Error Number: CS1026, ) expected
Line number 121, Error Number: CS1001, Identifier expected
Line number 123, Error Number: CS1525, Invalid expression term '='
Line number 123, Error Number: CS1012, Too many characters in character literal
Line number 125, Error Number: CS1022, Type or namespace definition, or end-of-file expected
Line number 126, Error Number: CS1022, Type or namespace definition, or end-of-file expected
Line number 162, Error Number: CS1022, Type or namespace definition, or end-of-file expected
