Sathishkumar_C's avatar
Sathishkumar_C
9 years ago
Date - Display - Working days
Hi everyone...
  1. When i use the project management the date is displayed as  like "Month/Date/Year". Is there any solution to like this "Date/Month/Year".?
  2. when assigning activities with date to any Identities Aras Scheduler takes "Saturday and Sunday" as holiday. It is not suitable for every company. By default can i set "Sunday" as holiday?
  Thanks. Regards, SATHISHKUMAR C.
  • eli_donahue's avatar
    eli_donahue
    Hi Sathishkumar, For your first question, you should be able to control the date format using your browser and client settings. For more information on locale formatting, check out the Configuring Internationalization guide. For your second question, you can edit the Business Calendar Year (Administration > Configuration > Calendars) to determine what days are counted as working days. If you only want to count Sundays as a "day off" rather than Saturdays and Sundays, you can try unchecking the Weekend Days Off field and then manually add Sundays as days off in the Exceptions tab. Eli
