eli_donahue
9 years agoCommunity Manager
Hi Sathishkumar,
For your first question, you should be able to control the date format using your browser and client settings. For more information on locale formatting, check out the Configuring Internationalization guide.
For your second question, you can edit the Business Calendar Year (Administration > Configuration > Calendars) to determine what days are counted as working days. If you only want to count Sundays as a "day off" rather than Saturdays and Sundays, you can try unchecking the Weekend Days Off field and then manually add Sundays as days off in the Exceptions tab.
Eli
