8 years ago
Customize landing page after login?
Upon login our landing page for users is empty (other than the toolbars)... Would like to edit this page to display links, or images, or some kind of info for users. Suggestions for getting started on this? Edit the aspx directly or is there another method?
  • Hi, I wouldn´t edit the default aspx to avoid update problems. You can change the landing page the following way: 1. Go to TOC -> Administration -> Users 2. Select a user 3. Change the Starting Page property in the Form. You can add additional Starting Pages in the List StartingPage List. The List values represent the corresponding ItemTypes names. And here I would start when creating a custom landing page. Create a new ItemType that use a custom HTML or ASPX page as TOC View. Put your custom page file in the customer folder in the codetree and then link it to a new TOC View item (e.g. ../customer/StartPage.html ). You can also take a look at the ItemTypes Design to Goal (Dashboards), Desktop or the SearchCenter. These ItemTypes also use custom views instead of the standard grid. If you want to provide your users more personal freedom for the landing page, check out this project: github.com/.../cui-select-starting-page Angela
