9 years ago
client error
we have installed aras innovator with all the default settings, The database was also created successfully but when we open browser with aras it shows mentioned error we tried IE11 and Firefox ESR Application Server URL: localhost/.../InnovatorServer.aspx Web Alias: InnovatorServer SMTP Server: queue Vault Name: Default Conversion Server Name: ConversionServer DB User: innovator Pass: innovator DB Name: InnovatorSolutions   ERROR: - <SOAP-ENV:Envelope xmlns:SOAP-ENV="">schemas.xmlsoap.org/.../"> - <SOAP-ENV:Body> - <SOAP-ENV:Fault xmlns:af="">www.aras.com/InnovatorFault"> <faultcode>SOAP-ENV:Server</faultcode> - <faultstring> - <![CDATA[ Database Name Or Database Description Is Wrong. (Check your request and server configuration file) ]]> </faultstring> - <detail> - <af:legacy_detail> - <![CDATA[ Database Name Or Database Description Is Wrong. (Check your request and server configuration file) ]]> </af:legacy_detail> <af:exception message="Database Name Or Database Description Is Wrong. (Check your request and server configuration file)" type="Aras.Server.Core.InnovatorServerException" /> </detail> </SOAP-ENV:Fault> </SOAP-ENV:Body> </SOAP-ENV:Envelope>   Please suggest
  • Hi there, In order to open the login screen, please try to navigate to the URL below instead: localhost/InnovatorServer The InnovatorServer.aspx page is not intended to be opened directly, so the error you are seeing is expected. Chris ______________ Christopher Gillis Aras Labs Software Engineer
