9 years agoAccelerator III
Timestamp error after applying 11.0 SP10 patch
Looking for some help. I was following along with the instructions in the "Upgrade from Version 11.0 SP8 to Version 11.0 SP10" directions, and I got to the point where you copy the contents of the .zip over tot he innovator and vault folder, re-set IIS portion and I have run into an issue.
The application will no longer display a login, and any attempt to login to a db shown by the the "aras innovator solutionupgrade" (import.exe), I am met with this error:
Login errors
****ErrorMessage****
faultstring: Failed login to Innovator; original error: SOAP-ENV:ServerThe type initializer for 'Aras.I18NUtils.TimeZoneInformation' threw an exception.The type initializer for 'Aras.I18NUtils.TimeZoneInformation' threw an exception.
faultdetail:Failed login to Innovator; original error: SOAP-ENV:ServerThe type initializer for 'Aras.I18NUtils.TimeZoneInformation' threw an exception.The type initializer for 'Aras.I18NUtils.TimeZoneInformation' threw an exception. Unable to login.
faultcode: -100
Any tips on what setting I should be looking to change?
There was something about changing the time zone settings inside the aras application, but since it won't launch...
