Duncanwilliamgibbons's avatar
QMS with Aras
Hi all
is Quality Management System (QMS) only available with full subscription or am I able to install it with my student license version. If so how do I go about doing this?
Thanks
  • Hi Duncan,
    You can download and install the QMS solution with the Aras Update tool available for download here. https://www.aras.com/support/downloads/
    QMS does not need a subscription, but the publishing features available with the Content Modeling Framework (which QMS is built on) does require a subscription.
    Hope this helps!
    • Duncanwilliamgibbons's avatar
      Thanks!
      Does this mean I can test the QMS without a subscription? Ive installed and run the updater but dont see the quality management tab in innovator
      • christopher_gillis's avatar
        Hi Duncan,
        Yes, you should be able to test QMS without a subscription. After running the install, you should see the new ItemTypes in the TOC under Quality Management.
        Could you let us know what version of Aras Innovator you are using? The most recent publicly available release would be 11.0 SP12. If you're using that version, could you also confirm that you've installed the 11.0R2 version of QMS?
