6 years agoCommunity Manager
Hi Wolf,
Looking at the logs, the error appears to be due to a timeout. This can happen occasionally for very long running queries. Could you try running the import again?
- wolf6 years agoIdeator II
Hi Chris,
really? I've tried several times, also with two further environments, same issue. Server is usually performant with SSD and enough memory, and even the huge package of "component engineering" which imports much more data than QMS, did run through smoothly?!
BR Wolf
