smira's avatar
smira
Ideator II
9 months ago
aras plm 11.0 -Authorization code verification failed(AP-00006...)
I migrated the system to a new server and can successfully log in to the migrated system.However,when adding a deliverable in Project Management task,the system  prompts"Authorization code verification failed(AP-00006...)"
We need everyone's help.How can this issue be resolved? Thank you !
  • Hi smira! It looks like you're using a partner solution from Broadway Consulting. I'm not sure if this is a common solution or something they built custom for your company, but someone from their team should be able to help you troubleshoot this error.
  • Is the new system still Innovator 11? Or did you made an upgrade?
    Check if you all server config files where customized correctly, including less known ones like Oauthserver/web.confall server configs correctly.
    • smira's avatar
      smira
      Ideator II
      Could it be a problem with the authorization code? All other functions work fine for us. Only when adding deliverables for the project task does it prompt "Authorization code verification is incorrect (AP-00006; pc20230608)".
        "Could it be a problem with the authorization code?" Yes definitely. But what kind of authorization code do they mean?
        I expected you to have trouble with the framework licenses. But you obviously are able to login, so I expect your framework license to be ok. I guess you reuse your existing license. Do you use the same MAC address?
        The only reference to some "authorization code" I know is to OAuth. Oauth errors can lead to "nothing work" to "something don´t work" which is more close to your error description.
        Questions:
        - Which Innovator 11 version do you use? Early I11 doesn´t use real OAuth as far as I remember. "Newer" versions like 11SP15 use OAuth to some degree.
        - Which version of Project Management do you use? Was Project Management a Part of your Innovator 11 installation? In I11 the app wasn´t a standalone application yet. You might need some patches. Can you compare your codetree files to see if your original I11 had any patches that are missing in your new installation?
        - Do you get the same error when using a different browser? Early I11 was a bit browser pecky.
    • smira's avatar
      smira
      Ideator II
      I installed Innovator 11 on the new server, and then restored the original database and associated it with the new Innovator 11.
