smira
7 months agoIdeator II
aras plm 11.0 -Authorization code verification failed(AP-00006...)
I migrated the system to a new server and can successfully log in to the migrated system.However,when adding a deliverable in Project Management task,the system prompts"Authorization code verificati...
- 7 months ago
Hi smira! It looks like you're using a partner solution from Broadway Consulting. I'm not sure if this is a common solution or something they built custom for your company, but someone from their team should be able to help you troubleshoot this error.
