Self Service Reporting, Concatenate Property Values
Hi All, I am trying to build a Basic report using SSRS. I have a requirement where in I want to concatenate values of two Properties and show it in a single Column, Is that Possible using SSRS ? Eg. the Item Type Name and Label should be displayed as "Name(Label)" in a single Column. Will I be able to use the Expression Property to achieve the above use case ? Also, Is there any documentation available which provides a detailed explanation on the SSRS Reporting Configurations ? Thankyou [emoticon:c4563cd7d5574777a71c318021cbbcc8]4.1KViews0likes5Comments
