How to trigger or test an activity escalation immediately without waiting
Hi all, I'm testing an activity escalation in a Workflow Map and would like to know how to trigger it right away instead of waiting for the configured escalation time to pass. Could someone share the standard ways to force or test an escalation in a test environment—for example, whether there is a scheduled task/agent or method that can be run on demand, or which date/timeout properties on the workflow activity or assignment determine when it becomes eligible for escalation? Thanks in advance for any help! David3Views0likes0CommentsAuto expand x-properties
We used to have a small javascript deployed on the server which made sure that x-properties was auto expanded when the user opened a Document: Now we are on release 35 and it same that we have missed this part and that the functionality on x-properties in forms have changed a lot. Does anybody have implemented a solution to auto expand x-properties on R35 (or higher) ? Many thanks in advance58Views0likes1CommentUsing LoadRunner with ARAS Innovator R35
We're attempting to use LoadRunner with our ARAS Innovator R35 instance to validate the load performance. When trying to record an initial script of simply logging into the application we're seeing load runner throw an error once the script recording is done : 'The recorded script contains no steps' Would anyone have any experience on getting LoadRunner working with ARAS Innovator? We're using LoadRunner version 25.3 and ARAS Innovator R35.107Views0likes0CommentsMaking 'Simple' search default in relationship tabs instead of 'Hidden'
Innovator seems to remember search filter criteria that has been previously used in Simple search on relationship tabs. This makes it cumbersome for users to know if they are really seeing the right data in a relationship tab which loads by default with the search criteria in 'Hidden' form. The user needs to change search mode to Simple and then only will they be sure there is no filter criteria there. Is there a way to default the search mode in all relationship tabs to 'Simple' to make this clear and obvious for users? Alternatively, is there a way to prevent Innovator from remembering search filter criteria on a newly loaded relationship tab?Solved355Views0likes2CommentsR35/R2025 toolbar redesign: Simplified Icons + Labels = Usability Nightmare – How can we revert this quickly?
Hi community, in general I am happy with most of the UI/UX improvements in R35/2025. Many of them are great ideas and we are happy that Aras added them. BUT: There is one "improvement" that I don´t like and I am searching for options to revert it as fast as possible. I am looking for a solution that I can reuse on every Innovator instance that doesn’t want to follow the new 'simplification' design trend. Aras has simplified the toolbar CUI buttons, aligning them more closely with the current - but questionable - trend of overly clean design. As a result, the icons have become harder to distinguish. To compensate, labels were added, but they take up a significant amount of space. The situation worsens when using the German or French language pack, where labels are typically 30- 40% longer. In that case, there’s hardly any pixel left for custom elements, often forcing the toolbar to wrap into a second row. This is the default search grid in Release 35/2025: This is a common layout that I use in I12/14: Many of my ItemTypes have one or two custom buttons in the toolbar. They often use labels so people can easily see that the custom buttons are unique and important for the specific ItemType. In the shown sample I even removed one default element ("Today") to save some space. Fun detail: Aras now uses the upload icon to represent 'share,' which doesn’t fit the context at all. This is especially confusing when custom buttons next to it actually perform "real" upload actions (like in my image)! How can we bring back the previous design fast? - I assume the additional labels can be removed in the language pack? - Update the icons via AML? What is your opinion regarding the design update? AngelaSolved287Views0likes2Comments
