Tech Tip: Filter a Tree Grid View with Parameters
Tree Grid Views are a great way to visualize hierarchical data in the Aras Innovator web client, however sometimes they can contain a lot of data. To help users hone in on the most meaningful data in a Tree Grid View, we can define parameters. These ...402Views0likes0CommentsMaximizing Modal Dialogs in Aras
Modal dialogs are frequently used to collect user input throughout the Aras Innovator client - in both "out of the box" and custom use cases. When using the standard modal dialog function, the size and position of the dialog is fixed. However, users ...386Views0likes0CommentsSetting Up Federation Between Aras Instances
The digital thread is key in our industry and the PLM Backbone is essential to make sure you can keep the dots connected in a single and safe location. But we know our industry is also made of alliances and partnerships that do not always allow shari...164Views0likes0CommentsAras Best Practices: Community Projects, Part 2
This post outlines some pitfalls to avoid when creating your Aras Community Project. If you missed our post Aras Best Practices: Community Projects, Part 1, be sure to check it out for even more helpful tips for project authors. Do Not: Use applySQL(...297Views0likes0CommentsMicrosoft Power BI Part I: Getting Started
Do you want to interactively visualize and analyze your data inside of Aras Innovator? In this article, I will review the steps needed to create Microsoft Power BI reports and describe how to embed them into an Aras form. 1. Setting Up Power BI ...554Views0likes0Comments
