How does the permission system work on database level?
Hi Community, In Innovator, we can use permissions to specify which users are allowed to view, edit, or delete an item. I have a federated item type with a custom onGet method. Since SQL federation with onGet bypasses the standard permission system, any restrictions have to be implemented within the SQL query itself. I am wondering whether it is possible to customize my federation solution to support the existing permission framework. In my case, I would like to use the built-in identities such as "Creator", "Owner", and "Manager" to provide a more "natural and consistent permission experience". This leads to the question: How does Innovator actually enforce permissions? In the end, all regular data comes from SQL tables, so Aras must be applying some kind of security logic at the database level. I did some research and discovered the following: In SQL Server, there are "secured" versions of the regular tables that combine the underlying data with the results of the innovator.EvaluatePermissions function. My theory is that when a user requests data (for example, "Show me Parts"), the data is not retrieved directly from the innovator.Part table, but rather through the secured.Part function. Has anyone ever tried to replicate this mechanism in the context of federation? Any tips or ideas? Angela80Views1like2CommentsxClassification Insufficient permissions
I have created xClasssifications with set of xProperties and linked them to Part ItemType. When I tried to added xClassifications it give's an error as below " You have insufficient permissions to perform 'classify' operation for item id '29F57869D3E348FA92AB855F6A029EFE' by xClass id 'F1D35D96534B47BAB447134E6C309CC5'. "95Views0likes1CommentExtending Permissions to Item Properties
Has anyone successfully extended permissions to the item property level? I need to configure property‑level permissions in Aras Innovator so that modification and visibility of specific properties on an ItemType are controlled by user identity, beyond the standard item‑level permission and lifecycle security. This cannot be a purely UI/visual restriction (e.g., hiding fields via Forms or client‑side methods only). It must be enforced as a true permission/authorization control so that users cannot modify restricted properties using AML, REST, external integrations, or custom clients. Example Situation: Starting with 3 ‘Property Permission’ sets, one for Electrical, Software, and Mechanical Each Permission Set has 4 identities, one for Mechanical Engineers, Electrical Engineers, Software Engineers, and Non-Engineers. The permissions allow all of the engineers to Discover / get, but only one engineering group can update, and non-engineers have no access. Then modifying the 'Property' itemtype to have a lookup property to permissions And creating an ItemType called ‘PropertyPermissionItemType’ with 3 properties 'owned' by the different engineering groups, linked to the previously created permissions And the idea is that these property Level permissions would determine who could view and update these properties. It seems like theres a basic structure for it, but what would have to be done to actually implement the permissions at this level?358Views0likes7CommentsJavascript Temporary Permissions
Good day all. I'm still using v11 SP10. How do I grant temporary permission for a user through Javascript? I want to add a Comments tab to our custom change ItemType. I have a script attached to an Action to open a dialog box so a user can add a comment. The Submit button runs another script to pull the comments field information and sends it back to the original script. The original script then creates a Comments relationship entry for the change. I have this working except when the change is in the In Review Life Cycle state for normal user, it works for admins. I want to temporarily grant Aras PLM identity to the user so it can be added. I don't want to allow users to be able to edit anything else in the change while it is In Review. Method: DEMO_Notes_Form // Aras Labs Project // Eli Donahue - 10/5/16 // // Call a custom form in a modal dialog // Perform some action based on the values returned from dialog // Aras Labs Project // Eli Donahue - 10/5/16 // // Call a custom form in a modal dialog // Perform some action based on the values returned from dialog var inn = new Innovator(); // var thisItem = document.getThis var topWnd = aras.getMostTopWindowWithAras(window); topWnd = topWnd.main || topWnd; // get form var formName = "DEMO_Change_Notes"; var fetchForm = this.getInnovator().newItem("Form","get"); fetchForm.setProperty("name",formName); fetchForm = fetchForm.apply("get"); // check form for error if (fetchForm.isError()) return alert("Can't find a form called " + formName); // get form params var params = { title: 'Change Notes', formId: fetchForm.getID(), // put your form's id here aras: aras, dialogWidth: 600, // set width int dialogHeight: 400, // set height int content: 'ShowFormAsADialog.html' }; var parentItem = parent.thisItem; var value = parentItem.getProperty("id",""); var userID = aras.getCurrentUserID(); var callback2 = function(res) { var innovator = new Innovator(); var partItem = innovator.newItem("sm_DEMO_NDR_Notes","add"); partItem.setProperty("source_id", value); partItem.setProperty("comments", res.param1); var resultItem = partItem.apply(); } // call form in dialog topWnd.ArasModules.Dialog.show("iframe", params).promise.then(callback2); return null; DEMO_SUBMIT-Notes // Aras Labs Project // Eli Donahue - 10/5/16 // // onClick field event for Submit button // Returns the form field values to the method that called the current dialog // get param1 field var wrapper1 = getFieldByName("comments"); var p1 = wrapper1.getElementsByTagName("textarea")[0]; // confirm fields were correctly retrieved if (!p1) { alert("Can't find field param1"); return; } // return entered values var retVal = {}; retVal["param1"] = p1.value; retVal["param2"] = sourceID; // retVal["searchResult"] = p3.value; parent.returnValue = retVal; parent.close();Solved271Views0likes4CommentsHow can i create new permission and add that in
Hello, How can i add new permission and add on add I am using the following mode, it is creating permission but not adding it Innovator inn = this.getInnovator(); string docid = this.getProperty("id",""); Item permissions = this.newItem("Permission", "add"); permissions.setProperty("name", docid); permissions = permissions.apply(); this.setProperty("permission_id", permissions.getID()); return this;Solved3.5KViews1like6CommentsPermission Per Item Control - Private Permissions
Hello, I am looking for a discussion/recommendation on a permissions question. For the Item Type Part, we want to do control on a part by part (Item) basis. I understand that we could do Private Permissions is there any other way? or is the Private Permission answer an acceptable way to do this.Solved200Views0likes3CommentsMAC Policy Issue in ARAS 31 – Need Help with Access Restrictions
Hi all, I’m working on implementing access restrictions for the a Itemtype in ARAS 31. There are around 46 records, and I want to group them into 5 categories. Each category will be assigned to specific identities, allowing controlled access based on the record's classification. To achieve this, I started configuring MAC policies. However, I’ve run into a few issues: The fields I need are disabled in the MAC Policy Condition Editor. User-defined properties are not accessible in the condition editor either. Has anyone faced similar challenges or found a workaround for this? Any help or guidance would be greatly appreciated! Thanks, Salini193Views0likes2CommentsUse Src Access on regular item type?
Hello Forums, I have a regular item type that is parent to some other regular item types. I.e. we have Item A that has a relationship to Item AB, and Item AB has a relationship to BB. A, AB, and BB are all regular items. I want A's permissions to cascade onto anything below, but it seems that 'Use Src Access' only goes as far as A to Ab (the relationship item), as opposed to also placing A's permissions onto AB. Can 'Use Src Access' reach AB and BB? Best Regards, Frank67Views0likes1CommentFeature licenses error when activate
We are using a stand-alone server currently until we get ARAS fully stood up, then we will go live. We received the feature license keys and went to activate feature key but we keep receiving the pictured error below. It also pops up upon entering our database. Has anyone seen the below error before?2.2KViews0likes4Comments
