Customizing BatchLoader in ARAS 31 to Add Users with Identities
Hi everyone, I recently migrated from ARAS version 11 to version 31. In ARAS 11, we used the BatchLoader tool to import user data from an Excel file, which included both user details and their associated identities. However, after migrating to ARAS 31, I noticed that the BatchLoader no longer supports adding users and identities together in a single operation. The AML mapping now restricts us to using only one ItemType at a time, which makes it difficult to replicate our previous process. Has anyone tried customizing the BatchLoader in ARAS 31 to overcome this limitation? I’d really appreciate any guidance or suggestions on how to achieve this. Thanks in advance for your help! — Salini54Views0likes0CommentsHow can I control behavior of BOM on revision up
Hi community, Here is an use case that User want to control Part by item that make the BOM are float or fixed when revision up. I read some solution that you can use a customized property and replace the action when creating a new revision. But I need more explain on doing this. Thanks to read this.36Views0likes0CommentsHow can I control/track floating behavior of Parts?
Hi community, I use floating behavior on certain Parts in the BOM. This way the BOM will always show the latest Part as long as the Parent hasn´t been released yet. But I wished we would have more control about the float action it self. I don´t want to use "fixed" behavior. It would be helpful to know that a automatic "float" occurred and which Parts were affected. I am thinking about two possible concepts: 1. Inform user before a float update will occurs (include information regarding the affected elements) 2. Track somewhere in Innovator which BOM elements were updated via "float" Does anyone know a solution for something like this? Or has any other idea how to use the "float" behavior in a more controlled way? Any input welcomed! Many thanks! Angela777Views1like2CommentsHow to detect when a BOM position floats automatically to next revision?
Hi community, when we use float/hard float behavior in a BOM, a new revision of a Part will automatically update the BOM of the parent Part. Is there any way we can detect when this kind of update event on a BOM position occurs? Thanks for any hint! Angela730Views0likes1CommentRelation and versioning
Hi, I have an ItemType STUDY with a property (type=Item) pointing on an ItemType CONTEXT. The CONTEXT is versionable and has a simple lifecycle WIP => REL. I would like that: When the relation is created, the STUDY is pointing on the last version/generation of the CONTEXT When the CONTEXT is modified (same version), the STUDY is pointing on the last version/generation of the CONTEXT When the CONTEXT is released (LF set to REL), then all STUDIES are now fixed on this version/generation To do that: I set the "Item behavior" of the property to "Float" On the LifeCycle, I set the ""Item behavior" of the state "REL" to "Fixed" But, the point (3) of my expectations doesn't work, if I create a new version, the study is pointing now of this new version. What should I do?1.8KViews0likes0CommentsIntegrating aras innovator with an external database
Hi folks, I have a question and i think you guys can help me. my question is how to change the property of operation number in process plan from Integer to a String. when i tried to change in the properties of mpp_operation which is a item type, it showing error that can't change the system properties. what can i do? because I have operation number something like A0, B0 etc.. and another question is how can i share data from aras database to another external database and vice versa, i mean how can i integrate aras innovator with an external database. Thanks folks..!!Solved4KViews0likes1CommentPurge and float
Hi, I create Itemtype A and B , both are version controlled and A has B as an item property defined as float. I create an instance of both and relate instance B to instance A . I modify both multiple times so they both go up several generations. When I purge instance A it goes to the previous generation with still referencing the latest generation of instance B . When I purge instance B I get an error instead stating that that specific generation of instance B is still referenced by instance A . 1. what is the Aras standard way of dealing with this situation? 2. what is the Aras standard way of dealing with a similar situation, but instead applied on relationship itemtypes? I'm having a hard time finding information on how to deal with the above 2 situations. Regards, /MB1.7KViews0likes1CommentWill Item Behaviour set on Life Cycle take precedence to a property Item too?
I have an Item “ItemA” which has a property “PropA” of type Item with Item Behavior as Float. If I set the Item Behavior on the LifeCycle of the “ItemA” to be Hard Fixed. Will “PropA” behave as “Float” (as set) or “Fixed” (by taking the precedence from Parent’s Life Cycle state)? I tried mocking this up. But “PropA” still has Float behavior (I expect it to behave it as Fixed :(). The Parent’s Life Cycle State’s Item Behavior does not take precedence in this case. Please clarify. Thanks in advance.2.3KViews0likes1Comment
