Report Manager shows blank page on Aras Innovator 14.35 CE – Hotfix and Reporting 29 guidance needed
Hello Community, I am evaluating Aras Innovator 14.35 Community Edition and am currently facing an issue with Report Manager, where the result page is displayed as a blank screen. Before asking, I would like to clarify that I believe I understand the separation of concerns, and I am seeking confirmation on the correct and minimal path forward. Environment Aras Innovator: 14.35 Community Edition Build: 14.35.0.44037 MS Build Number: 000000.00 Browser: Chrome / Edge (same behavior) OS: Windows Server (IIS) Observed issue When executing a report (Type: General) from Report Manager, the result page is blank. From the browser network trace, I can see that blank.html is requested with an incorrect URL where an X-salt token is injected into the path, for example: .../InnovatorServer/Client/X-salt=std_14.35.0.44037-X/scripts/blank.html Instead of: .../InnovatorServer/Client/scripts/blank.html The AML itself executes successfully (InnovatorServer.aspx returns 200), so the issue seems to be on the client / UI side. What I understand so far Please correct me if anything below is wrong. 1. Hotfix / Patch Hotfixes apply to the Innovator core (Server / Client). MS Build Number = 000000.00 indicates that this environment is likely running a base build without Hotfixes applied. Therefore, this blank page issue may already be a known issue fixed by a Hotfix. 2. Reporting Aras Reporting is a separate product and installer. Reporting 29 requires a dedicated license (Aras.Reporting) and installation. Reporting 28 is not required if installing Reporting 29 as a new installation. My questions To proceed efficiently without rebuilding the environment, I would appreciate guidance on the following: 1. Is it correct that applying the appropriate Hotfix for Innovator 14.35 is a prerequisite, and that Reporting alone would not resolve the blank page issue? 2. Is the blank page / X-salt URL issue a known problem in the base 14.35 build that is addressed by a specific Hotfix? 3. For a Community Edition evaluation environment, is it realistic to: obtain the required Hotfix, and obtain the Aras Reporting 29 CD Image as part of the same guidance / recommendation? 4. If Reporting 29 is installed after the Hotfix, should Report Manager work as expected without additional undocumented steps? Goal / Constraints The goal is to evaluate Report Manager functionality. I would like to avoid rebuilding the existing test environment if possible. I am looking for the shortest correct path, even if it involves multiple steps, as long as the sequence is clear. Any advice, confirmation, or references would be greatly appreciated. Thank you in advance.219Views0likes2CommentsNext new open release? Will we get a Release 2024?
Hi community, does anyone know what will be the next open release after Release 2023? Will it be Release 2024 or Release 2025? I don´t want to appear ungrateful and I am very happy with large parts of Release 2023. It´s just an information that would be helpful regarding planning update. If updating to Release 2023 while Aras is planning to deploy Release 2024, I'd rather wait with the actual update and just do the preparations. This would prevent me from having to go through the same process twice. Would be happy if anyone knows more :) Angela93Views0likes2Comments
