eli_donahue's avatar
eli_donahue
New Member
8 years ago
Aras Mouse Over Help
Provides help text for fields appearing on a form as the user hovers over the field and field label.
Form hover help example
Interested in this project?
https://github.com/ProcessPLM/Aras-Mouse-Over-Help
Contributors
Darryl Poore, Aras
License
License information not provided.
1 Comment
  • I have been using this in v11 SP10 for a while now.  In the last two days I have noticed an error come up when opening a Part.  I'm not sure what the problem is with this.  Any help would be appreciated.  Thank you.
    [embed:dc8ab71f-3b98-42d9-b0f6-e21e02a0f8e2:7757a54a-0b0c-4a53-9897-5cf35fbd41a5:type=text&text=Internal%20Error%3A%20event%20handler%20failed.%20Event%20handler%20failed%20with%20message%3A%20TypeError%3A%20Cannot%20set%20properties%20of%20null%20%28setting%20%27title%27%29%20%5Bfunction%20onformpopulated%24user%24handler%28e%29%0D%0A%09%09%09%09%7B%0D%0A%09%09%09%09%09try%0D%0A%09%09%09%09%09%7B%0D%0A%09%09%09%09%09%09%09if%20%28onformpopulated1%28e%29%20%3D%3D%3D%20false%29%0D%0A%09%09%09%09%09%09%09%09return%20false%3B%0D%0A%09%09%09%09%09%09%09if%20%28onformpopulated2%28e%29%20%3D%3D%3D%20false%29%0D%0A%09%09%09%09%09%09%09%09return%20false%3B%0D%0A%09%09%09%09%09%09%09if%20%28onformpopulated3%28e%29%20%3D%3D%3D%20false%29%0D%0A%09%09%09%09%09%09%09%09return%20false%3B%0D%0A%09%09%09%09%09%09%09if%20%28onformpopulated4%28e%29%20%3D%3D%3D%20false%29%0D%0A%09%09%09%09%09%09%09%09return%20false%3B%0D%0A%09%09%09%09%09%09%09if%20%28onformpopulated5%28e%29%20%3D%3D%3D%20false%29%0D%0A%09%09%09%09%09%09%09%09return%20false%3B%0D%0A%09%09%09%09%09%09%09if%20%28onformpopulated6%28e%29%20%3D%3D%3D%20false%29%0D%0A%09%09%09%09%09%09%09%09return%20false%3B%0D%0A%09%09%09%09%09%09%09if%20%28onformpopulated7%28e%29%20%3D%3D%3D%20false%29%0D%0A%09%09%09%09%09%09%09%09return%20false%3B%0D%0A%09%09%09%09%09%7D%0D%0A%09%09%09%09%09catch%20%28exp%29%0D%0A%09%09%09%09%09%7B%0D%0A%09%09%09%09%09%09aras.AlertError%28aras.getResource%28%27%27%2C%20%27ui_methods_ex.event_handler_failed%27%29%2C%20aras.getResource%28%27%27%2C%20%27ui_methods_ex.event_handler_failure_msg%27%2C%20exp.description%20%3F%20exp.description%20%3A%20%28exp%20%2B%20%27%20%5B%27%20%2Barguments.callee.toString%28%29%2B%20%27%5D%27%29%29%2C%20aras.getResource%28%27%27%2C%27common.client_side_err%27%29%29%3B%0D%0A%09%09%09%09%09%09return%20false%3B%0D%0A%09%09%09%09%09%7D%0D%0A%09%09%09%09%7D%5D%20Client%20Side%20Error]
