Maddy's avatar
Maddy
9 years ago
Workflow Activity not get created when new revision is created
Hi, I have part lifecycle, in which I have 3 states Preliminary, Review and Released, On Released state I give permission to update, so it will create a new revision of , this all works fine, State of the part also get change from Released to Preliminary, but workflow task will not get create for B revision.   Thanks.
  • Hey Yoann, Thanks, as you said I did changes in Part ItemType and it works. Thanks once again. Regards, Maddy.
  • Hi Yoann, Thank you so much for this information, I will try as you said, that uncheck the default workflow from Part Itemtype. and could you please give me any link from where I can learn ECO and DCO, because I searched material for DCO but I couldn't find anything. Thanks once again.
  • Hi Maddy, Yeah usually Worklfows and versionnable items don't go along very well. But here's what you can try. Instead of setting the workflow as default in the itemtype definition, uncheck it (keep it just attached) and call the workflow from the preliminary state in the lifecycle definition. I think it should work better. If it doesn't I know we have make it work in the past so I would then look for another solution. But once again, workflow on a part is usually not recommended. If the aim is to drive the lifecycle state, usually it goes through an ECN, which has its own lifecycle, its own workflow and is not versionnable.
