jh's avatar
jh
10 months ago
where can i find documentation
I'm a new comer to  ARAS. Where can I find the documentation, especially for the control  listbox multi select  that I need to use
  • asebastian's avatar
    asebastian
    Hi JH,
    Could you provide more info about what you're trying to achieve with the listbox multi-select? That will make it easier to point you in the right direction.
    As far as general documentation you can find it here: https://aras.com/en/support/documentation
    • jh's avatar
      jh
      Thank you for your reply.
      For example, I want to use these HTML controls. Where can I find documentation on how to use them, or are their usage methods just the general HTML usage methods.
      Regarding the use of listbox multi-select, I want to enable multiple selections, concatenate the selected values, and store them in a field. When I make modifications, it should automatically check the options I have selected.
