chenze's avatar
chenze
8 years ago
Visual Collaboration Viewer
Hello, I tried to use visual collaboration. I uploaded the CAD file(catia, creo) into Innovator, but the Viewer(sidebar button) was not visible. It's the first time I tried to use this function, and I have subscription, but not sure how to configure it to get the Viewer. Should I install some component or check the file format? Thanks chenze
  • Hi chenze, In addition to activating your feature license, you will need to also follow the steps in Section 2 of the Visual Collaboration Administrator Guide which you can find in the Documentation folder of the Aras Innovator CD Image. Chris
  • Hi Chris, many thanks for the reply. Must "Windows Authentification" be firstly set up before I install PDF-Viewer for Visual Collaboration? Regards Chenze
  • Hi Chenze, Windows Authentication is not required to install the PDF-Viewer. Chris
  • So what the formats can the viewer be compatible with? Only 3D model? or more...
