The following log has been created:
<LOGFILE>
<event time="2019-09-25 13:07:52Z" reason="soap_action" TickCount="3731328" dt="16" message="generateNewGUID" />
<event time="2019-09-25 13:07:52Z" reason="requestDom" TickCount="3731328" dt="0" />
<SOAP-ENV:Body>
<generateNewGUID>
</generateNewGUID>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
<event time="2019-09-25 13:07:52Z" reason="Aras.DerivedRelationships.Synchronization" TickCount="3731328" dt="0" message="
before call of ProcessNode
Working Set
Qual_Item;orig_root_set;new_root_set;predecessors;successors;orig_succs
<event time="2019-09-25 13:07:52Z" reason="performance" TickCount="3731328" dt="0" message="16" />
<event time="2019-09-25 13:07:52Z" reason="responseDom" TickCount="3731328" dt="0" />
<SOAP-ENV:Body>
<Result>
<id>F7243B89F71C41B983720857A58E6122</id>
</Result>
</SOAP-ENV:Body>
<event time="2019-09-25 13:07:52Z" reason="soap_action" TickCount="3731359" dt="16" message="BeginTransaction" />
<event time="2019-09-25 13:07:52Z" reason="requestDom" TickCount="3731359" dt="0" />
<SOAP-ENV:Body>
<BeginTransaction>
</BeginTransaction>
</SOAP-ENV:Body>
<event time="2019-09-25 13:07:52Z" reason="cachedriver-key" TickCount="3731359" dt="0" message="GetLookupMessage:ApplySoapAction_ActionNotSupported:en" />
<event time="2019-09-25 13:07:52Z" reason="cachedriver-value" TickCount="3731359" dt="0" message="Aras.Server.Core.LookupMessageInfo" />
<event time="2019-09-25 13:07:52Z" reason="Aras.DerivedRelationships.Synchronization" TickCount="3731359" dt="0" message="
Working Set
<event time="2019-09-25 13:07:52Z" reason="RollBackAllServerCaches" TickCount="3731359" dt="0" message="1 keys" />
<event time="2019-09-25 13:07:52Z" reason="performance" TickCount="3731359" dt="0" message="16" />
<event time="2019-09-25 13:07:52Z" reason="responseDom" TickCount="3731359" dt="0" />
<SOAP-ENV:Body>
<faultcode>SOAP-ENV:Server</faultcode>
<faultstring><![CDATA[The action BeginTransaction is not supported.]]></faultstring>
<detail>
<af:legacy_detail><![CDATA[The action BeginTransaction is not supported.]]></af:legacy_detail>
</detail>
</SOAP-ENV:Fault>
</SOAP-ENV:Body>
