I would be very interested in how to configure onprem to use Windows Login and Microsoft Authenticator.
Hey Bryan, when you say Windows Login, are you referring to Active Directory or another service?
- bryan-riley1 year agoCreator II
yes, Active Directory
- eli_donahue1 year agoCommunity Manager
Have you checked out the Windows Authentication Setup guide in the CD image documentation folder? It doesn't cover Microsoft Authenticator, but it might help with the AD configuration. I can look around to see what other 2FA options might be in use for on-prem customers.
- ag-pmi1 year agoIdeator I
Hello Eli. I'm new to Aras and trying to set up SAML with Azure AD for SSO. I've configured both the Azure app and the OAuth plugin in Aras, but SAML doesn't seem to be working (it's like the mechanism is ignored). I also tried setting up Windows authentication as per the documentation, but when I try to login I get the error: "You do not have a valid license required to use feature Aras.ExternalAuthentication."
Could you clarify if any special licenses or plugins are needed for SAML or Windows AD integration? My license is "Verified", but now I'm a bit confused on what else is required.
Thanks!
