eli_donahue
8 years agoCommunity Manager
Hi bdc604,
In Innovator, the default behavior is for an item's workflow to start automatically when that item is saved to the database for the first time. It is possible to manually start a workflow, but that would require some code and customization as you mentioned. If do you need to manually initiate workflows in your Aras environment, you can adapt the labs_WorkflowLaunchExample method from the AutoWorkflowLaunch community project on the Aras Labs GitHub.
Eli
