eli_donahue
9 years agoCommunity Manager
Hi Maddy,
If you are an Aras subscriber, I would recommend checking out the Aras Scheduler Service to schedule a daily check on the "Last Date" property on your documents. The use case you've described is similar to the sample provided in the Aras Scheduler Service documentation.
If you are not an Aras subscriber, you can create a custom server method to check the "Last Date" property and send emails when the "Last Date" meets your criteria. You can execute this method via a manual action, or you can create an external service/program that will periodically execute your custom method via AML.
