eli_donahue
8 years agoCommunity Manager
Hi Obi8,
It sounds like the installation is not completing successfully. Can you confirm whether the installer finishes with a success or failure message? Also, are you installing Innovator with the default settings (like install path and web alias) or are you using custom settings?
Eli
