eli_donahue
8 years agoCommunity Manager
Hi Obi8,
I just noticed the following line in your previous post:
Is it correct that the InnovatorServerConfig file is empty during a new installation?This is not expected behavior. It sounds like Innovator did not install correctly. I recommend that you uninstall Aras, make sure you have IIS and other required components installed on your server (.NET Framework 3.5 and 4.0 or higher, ASP.NET, etc), and try installing Innovator again. Eli
