eli_donahue
7 years agoCommunity Manager
Hi Obi8,
It sounds like there is a syntax error somewhere in an XML file, either the web.config file that you updated or the InnovatorServerConfig.xml file. Can you undo your changes to the web.config file and try logging in again? If you get an error, please post it here.
Eli
