Hi CC,
This is most definitely possible. There are a few important things to note when installing your second instance. You'll have to ensure that the second instance has unique identifiers. This means it needs it's own file path, database name, conversion server path, and web alias. Each install will create a new database and each instance of innovator will have it's own vault. Going through the installation documentation in the 12 CD image should help you figure out how to set each one of these individually. It should be pretty straightforward, but let me know if you have any issues!
AJ
Hi Sebastian,
We want to test the version 12, so firstly in parallel to the 11SP12. We stopped installation since we had a doubt.
Installation is done in a dedicated directory, the conversion server path is also specific, based on dedicated web alias, but what about the "service agent" (the wizard is in French, so the translation could differ...)?
Defaut value is http://localhost/InnovatorServer/Server/InnovatorServer.aspx it sounds strange since this is the same for the both Innovator versions...
Any suggestion?
Thank you,
Vincent.
- asebastian6 years agoCommunity Manager
Hi Vincent,
From my experience I believe yuou should set the value to http://localhost/{webalias}/server.
I'm unsure why the default doesn't automatically update when the web alias is entered, but you'll want to make sure to set it properly.
AJ
- DVincent6 years agoIdeator II
Hi Sebastian,
That corresponds to my doubt since the path is asked before the definition of the {webalias}.
I asked my 'administrator' to do that... I'd confirm it as soon as installed.
Thanks,
Vincent.
